I'm removing the powerhead of a 1980 Johnson 140 so I can fix up all the worn pins etc lower down. I believe I've removed all the bolts to allow the powerhead to be lifted free of the exhaust, but there is no give when I gently prise with a crowbar between the powerhead and exhaust at the rear. I don't want to hire an engine hoist yet, as I suspect it will just lift the back of the boat up! Have you any tricks for removing the powerhead - any hidden bolts not mentioned in the Clymer Evinrude/Johnson outboard shop manual 48-235hp? Model No. is J140TLCSA on the bracket, but the powerhead has been rebuilt at some stage (before I got it) and the welsh plug has the number 0481878 on it.
