Re: 75 HPJohnson wiring on coils
Hi bear<br /> The short wire goes to ground. The long wire goes to the points along with the two kill wires from the engine, the condencer is also connected at this point. Don't forget to connect the spark plug leads, they go in the hole with the pin in it. bear, you really should have a manual for this work. From the sounds of things this motor probably has other needs as well. You know if you don,t want to or can't shell out the $35. for a manual, check one out at your public library. Anyway good luck and get your motor running.
