Re: 135 evinrude
Just a couple more things to do till the snow melts. Disconnect the shift cable and shift to reverse by hand. (don't forget to turn the prop while shifting) Compare the shift lever postition to the position it's in with the shift cable attached and in reverse. If the shift cable looks to be "kinked" or bent at the casing guide, thats the plastic thing at the end of the cable, after shifting to reverse,replace the shift cable.
