Recently Posted: 1985 150 Johnson
Dagsr
Still having the Problem, The first 15 minutes of running above half throttle feels like im turning the key on and off,does this about four or fivr times and somtimes even stops completly!Restart if it dies ,and will run great the rest of the day,I checked everything you guys mentioned ..Water none,Kill swith ok,,Primer bulb stays firm,Checked all wires ,,grounds ect... Could somthing elec.be going out ,but when motor heats up maybe causes it to get a better conection or somthing,,,I dont know Guys Im lost...Thanks for Any thoughts
Mumblerone
Re: Recently Posted: 1985 150 Johnson
Have you looked at the Power Pack? :( Sure sounds like it. ;) There is some good people out there that will tell you how to check it. I just went out an bought a new one last spring...when they told me that sounded like the problem. About $250.00. :rolleyes:
JB
Ahoy, Crawdaddy.<br /><br />I think you are on the right track. Try preheating your powerpack with a hair dryer and see if she still needs a long warm up before running smooth.<br /><br />Good luck. :)
Dagsr
Looks like Im going to have to buy a Power Pack Thanks guys
Dagsr
JB ,She will sit and Idle all day
JB
Outboards lie. :eek: <br /><br />Idling with no load is when they lie the most. :)
xp150
I have a 1989 Evenrude XP150. Had the same problem, took it to the dealer and had it run on the dyno, came up bad power pack. I ordered one for a $140 delivered from www.seilermarine.com.<br />Took about 40 min to change it myself, ran great. <br />Dealer wanted $230 for part and install.Hope this helps.
