Re: fisherman year and hp rating
Hi Marc 12<br /><br />The 6 HP fisherman is a brilliant motor. You can only check if the shifter arm moves the shifting rod all the way into forward, Is neutral in the middle of the shifting movement ? Move the lever a little bit foreward and reverse, while you turn the propeller a little by hand. Notice if it rests in neutral in the middle between it hits f/r gears. If it does so, it is probably a worn clutch "dog" in lower gear unit, one of the few failures these models have once and in a while.<br /><br />While you are at it, change the impeller if it hasnt been done the last few years. Get a manual first.
