I HAVE A 82 JOHNSON 25HP THAT HAS BEEN LEAKING ORANGE JELLY LIKE GREASE OUT THE WATER JACKET/RIGHT AROUND THE SPARK PLUG, AND IT IS ALSO GOING OUT IN LITTLE BEADS THROUGH THE EXHAUST, REALLY LEAVING A MESS ON THE LAKE. I DID A COMPRESSION TEST AND BOTH CYLINDERS ARE AT 90LBS, I DID THIS COLD AND WITH A CHEAP TESTER.I CHANGED THE HEAD GASKET LAST FALL AND THE PROBLEM DID'NT CHANGE AT ALL. THERE WAS A SMALL AMOUNT OF WATER IN THE LOWER CYL EACH TIME I RESEATED THE HEAD GASKET.I'VE READ IN THE FORUM ABOUT EXHAUST COVER GASKETS, OR MAYBE I HAVE A CRACKED CYL WALL. I'VE OWNED THIS MOTOR SINCE NEW AND REALLY LIKE IT. ANY RECOMMENDATIONS FOR TESTS I SHOULD RUN TO PIN POINT THE PROBLEM,OR SHOULD I JUST WRITE IT OFF. ANY FEEDBACK WOULD BE APPRECIATED
