mlcatlopez
Thread starter- Joined
- Oct 30, 2002
- 56
I have a 30hp johnson motor, mounted on a 13 foot Boston Whaler. The engine is in great shape.I haven't run the engine in approximately 10 months and I decided to take it out this passed weekend. The gas level was at 1/2 tank full so I topped it off with new gas mixed with the proper amount of oil. When I put it in the water it ran long enough to get me out in open water about 300 feet from land and then it stalled. I was able to get it back to the dock and then I went to a marine store and purchased a water separator, filter and dri fuel. after adding all these new parts the engine would start and then make a spew sound just before it would turn off. I got it home and drained the fuel, mixed new fuel, disconnected the house from the fuel tank and used the new fuel to run through the fuel line. The engine continued to function the same way so I took the cover off the engine and turned a red valve, which I think is called the primer solenoid. I could here the fuel run through something, it may have been the carburter. I then started the engine and it ran for a few minutes and then shut off
. This time I notice oil running down around the propeller. I don't understand what has gone wrong. Can someone help me?
