wiring diagram for tilt and trim
karlp
I need the complete wiring diagram for a 1991 70HP Johnson Tilt and Trim. I am installing the parts on my 1978 70HP Johnson. Any assistance or comments will be appreciated.
93bronco
Ensign
Re: wiring diagram for tilt and trim
if you post your email address i will scan and send you a diagram.
karlp
Thanks, email address is
93bronco
Ensign
just sent you a 1990 to 91 tilt/trim and a 1978 tilt/trim diagram. hope that helps.
karlp
Thanks. Received a number of files but can not pull them up with my programs. What type software was used ? My system calls them ".max" files but will not read them.
Hooty
How many wires to the trim motor? Two or three?<br /><br />c/6<br /><br />Hooty
karlp
To Hooty,<br /><br />Two wires, a blue and green. Thanks
karlp
To 2K BOAT,<br /><br />Yes I have them now. Had to get some different viewing software off the internet. Thanks
lasvegas
send me a diagram for tilt and trim for 84 140hp 2 wire johnson
bktheking
Start a new thread LasVegas, no one will see your post!
Boss Hawg
Code:
lasvegas
Yes- That was also a bit rude :confused:
bktheking
Like I always say, other people kids!
Quite rude
Faztbullet
You will also need the trim relay box off the 1991 model to make this work. 1978-1981 used a 3 wire motor that had seperate ground and usually a single relay/solenoid, newer 2 wires motors just reverses polarity to the wires.
lasvegas, bktheking is correct in his statement. start a new thread of your own. this is a 6 year old thread. are you adding the 2 wire system to the motor, or do you have some wiring problems with the existing system?
jmckinney
93bronco,
saw your post that you had a wiring diagram for a 91 johnson tilt and trim for a 70 Hp. WOuld that be the same for a 120 Hp 91 Johnson.
If so would you email it to me at jmckinney@mchsi.com
I need i tbecause I walked out to my boat today and hit the power trim once to lift it off its supports and it got stuck and I had to open cowling and disconnect wires. Could it be a solenoid? or stuck switch ?
It would be much appreciated
