cvlngineer
- Joined
- Jan 22, 2002
- 137
Re: 1975 70 hp Johnson...Take off problem...Update and more information
ob,<br /><br />That looks like the one. Except, in mine, there are two pressure relief valve springs (#23), two pressure relief valves (#101), and two relief valve grommets (#78). They sit next to each other in the same chamber. Other than that, it looks the same. It looks like I did get the thermostat installed in the right direction. <br /><br />I tore the crap out of the housing gasket, hopefully my gasket sealer will work. If not I will have to run over to the shop here and see if he has another one.<br /><br />Thanks,<br />cvlngineer
