1979 115 Johnson starter problem
wordmaster
When starting, the starter works, but there is a loud whining noise until the motor actually cranks. It sounds like when you try to start a motor that is already running. Any ideas? The teeth on the bendix appear to have only a little wear right at the top. Also, this motor seems to be very cold natured, takes 5 minutes or so to warm up and run right, then runs perfect. Is this normal for this motor? All help and info appreciated.
Joe Reeves
Re: 1979 115 Johnson starter problem
Web.... Those bendix drives actually have a clutch within them. Look directly at the starter bendix drive when this problem is taking place. If the top nut/section of the armature is turning faster than the bendix gear itself, replace the bendix gear drive assy.<br /><br />Check all of the cables that are associated with the battery, solenoid, and starter. If any of them feel overly warm or hot, there is a loose or dirty connection associated with that cable.<br /><br />If all of the above check out okay, I'd suggest removing, dismantling, and inspecting the starter itself.
wordmaster
Thank you very much for your help, I will do as you say. If I need a new bendix assy., can you recommend a good place to get one?
Joe Reeves
WebWizard.... Your local Evinrude/Johnson dealership should be able to supply you with that item. You might also check with NAPA.
