1994 15hp Evinrude won't idle. <br /><br />I just found this board and am amazed at the wealth of info located here. You guys seem to really know your stuff and are willing to share freely, what a great place.<br /><br />I tried searching the board for my problem but haven't seen it listed so I thought I'd ask and see if there might be a suggestion.<br /><br />The motor is a 94 15hp Evinrude Model # E15REOD. I use it year round, it never sits idle more than a few weeks. I've performed general maintainance on it every year and have never had any trouble at all until now. <br /><br />The motor will not idle, it runs fine by just giving it just a little gas. This problem is the same in gear while moving slowly or out of gear. If I don't touch the throttle at all it will idle down for a few seconds then it seems to have a slight miss that is the begining of the problem. As soon as it misses the motor seems to be starved for fuel and dies. I have figured out that if I give it half choke as soon as I hear the miss then push the choke back in the motor will stay running. <br /><br />Today I replaced the plugs and sprayed a can of carb cleaner through the motor. The problem is still there. Like I said earlier, if I give the motor any gas at all it runs perfect at all RPMs.<br /><br />Any ideas or suggestions would be much appreciated.<br /><br />Rob
