emtmedic99
- Joined
- Mar 14, 2003
- 14
I have a general question and hope you can help. I have a 70hp Evinrude. It is on a 89 Tracker boat. I took the boat out of winter storage. I raised the motor to install the transom saver, after I raised it up and went to lower it back down, nothing happened. It wont go up or down. I have checked everything I know to check. I have power everywhere but still can't get the motor to move. When you push the up or down button from the motor or from the throttle, I get a click when I try to go up and a buzz when I go down.I pulled the relays out and swapped them. Same thing. I used a test probe and I have power through the switches, relays, power harness all the way to the pump motor. It is full of fluid. I can do a manual release and it will go down. My question is this...Is this a problem with the motor or could it be something else. It seems is tho the motor is froze or bad, but I am not real sure how to determine if the motor is bad. The model # on the motor is TE70TLCEM.
