Re: 1975 115hp Johnson won't idle
Nscarpi..... The compression on that engine should be in the range of 100+ psi and even on all cylinders. The spark (with the s/plugs removed) should jump a 7/16" gap on all cylinders with a strong blue flame.<br /><br />The spark plugs should be Champion QL77JC4 or L77JC4 plugs, gapped at .040 .<br /><br />Assuming the above are as they should be, I would look at the following areas.<br /><br />Possibly you have overlooked something in the carburetors (it happens). If those carburetors have a small brass tube within the larger brass high speed nozzle, that small tube is a slow speed passageway that is clogged easily.<br /><br />The linkage connecting the carburetor throttle arms may be improperly adjusted whereas at idle, one of the throttles is still open somewhat.<br /><br />The cam to carb roller (synchronization) is not aligned properly. The throttle should just start to open when the scribe mark on the cam aligns perfectly with the center of the roller.<br /><br />The flywheel.... Usually, if the flywheel key shears even slightly, the engine will not run. However, recently I have come across one engine that would run with the key slightly sheared. It may be possible that you have a problem of this nature.<br /><br />If you have had the flywheel off and upon re-installing it, did not torque it properly, the key could shear. It's something worth looking at. The flywheel nut must be torqued to exactly 105 foot pounds.<br /><br />Let us know what you find.
