Re: 1963 Johnson 3 hp Seahorse (2 cylinder) mix
Actually, there is no difference between a '63 and '64 OMC 3hp. And neither one has a single needle bearing in the whole motor. Check out the parts list and clearance specs if you want to. I heard it straight from the (Sea) Horse's mouth..."We just found out that it will run on less oil". Also, in 1964 they recommended 50:1 only with Johnson/Evinrude oil!!!
OK, having said that, would I myself run a 3hp on 50:1? Not if I valued the motor. I run mine on 24:1 It may run on 50:1, but I feel it will run longer on 24:1
