I just bought my first boat with a 48 HP 1987 Evinrude. I listened to the motor before purchasing and it started right up and sounded fine to my untrained ear. On visual inspection I couldn't see any obvious damage or leaks. But being new to this I brought it in to a shop to have checked out before I took it out for the first time.<br /><br />The mechanic tells me oil in the lower unit is "a little milky" which usually indicates a problem. He also thought the motor was running rough and needed carbeurator work. He said the compression was 155 on top and 160 on the bottom. His recommendation was cleaning the carb (1 1/2 hrs work), and resealing the lower unit (5 hrs work plus parts) and replacing the impeller for good measure.<br /><br />Does this make sense? I really don't want to end up having my motor die on my the first few times out, but I'm wondering if these are things that will cause major problems. Can I monitor either problem, or do them down the road without causing further damage? The previous owner swears it runs great and has even offered to go out with me.<br /><br />Thanks.
