Re: RPM MAX/sneezing
Good points DH!<br /><br />ok.. the port timing thing has me a little interested... You are referring to exhaust port timing? Needs to be raised to obtain 8800?!?(no I really don't need 8800, just curious). What about the intake ports?(try to be open minded here. I have read tons of posts here and the answer is all the same... don't Screw with it(unless you know what you are doing). The pain in the butt about this is that there are 8 ports pr. clyinder, 4 of which are very deep, the other 4 are much easier to do.<br /><br />I talked to a fella last week and he also told me to stay away from 6200 rpm! Harmonic balance problem there. Above or below is ok, just not the 6200. Said the crank would snap, yikes!<br /><br />Since I work for a machine/forging shop I have the ability to do whatever I wish here at night, as long as I keep the million dollar machines running I have spare time to do "other" things.<br /> I was considering doing some port work to add to the other mods I have added. I have already cleaned up all the casting imperfections, and cut the pistons "excess baggage", and balanced. A little port work would be nice but this work takes a little experience. .020 raise on the exhaust ports would probally add some r's and HP? OR... not worth doing? Or the wrong amount?<br /><br />Oh.. I don't have the air jets on either set of carbs I have.. I have 1 set that are 1 5/16(1973 carbs) and another set of 1 3/8 from a 140. The manual(clymer junk manual) says if I have the 1 3/8 to replace them because they run too lean. This one I can't understand.... too lean.. add bigger fuel jet's/ smaller air jets.. but replace them.. seems foolish.
