hammer250v8
- Joined
- Nov 15, 2002
- 123
i can't figure this one out???<br /> after i had my lower unit replaced with a used one, my evinrude shift's REAL hard!(almost need two hands) i have kerhaufer controls in my baja.checked them and look good and free of binding. checked cable at the midsection linkage,looked ok. removed cable and by itself moved very easy. moved shift linkage on motor without cable and that moved easily also! as soon as the cable is hooked back to the shift arm, it returns to hard shifting! any ideas. could they have installed my lower unit wrong? there are no tension adjustments(that i can't find) my cable is black with red end's on it, it also has a barrel part close to the end with slots in it with a clip on the back slot. any ideas? thanks...james DHADLEY....any luck on the kingfin?
