Re: 1990 40hp Evinrude VRO
Hi kritzi,<br /><br />I run 2 of exactly the same motors. There is no way gravity will feed the carbs unless your fuel tank is substantially higher than the carbs. Even then, I'm not entirely sure that the vro will allow free flow through it. <br /><br />do yourself a favour though, clean out your oil tank, the pickup filter etc and refill with clean tcw 3 oil. Disconnent the oil supply hose at the VRO and pump the oil bulb untill oil comes out the hose. Reconnect and fasten the hoseclamp securely.<br />Measure the level of oil in the tank and run the motor on premixed fuel 50:1 untill you are sure the level of the oil is dropping. That way you know the oil supply to the vro is good.
