Trim Tilt Fluid
larryo
Can someone tell me where the port to receive the trim/tilt fluid is on my 87 Johnson 150 HP VRO. thanks
ob
Re: Trim Tilt Fluid
Yeh larryo,its on the side of the oil reservoir which is on the oposite side of the T/T bracket as your T/T motor.Starboard.
larryo
Re: Trim Tilt Fluid
Thank you OB, would there be a screw there?
ob
Re: Trim Tilt Fluid
Yup.And its got an "o"ring under the screw head for a seal.
larryo
Re: Trim Tilt Fluid
Thank you. Is there a trick to keeping the fluid in the reservoir, it's coming out as fast as I can squeeze it from the tube. larryo
