transom tie down straps
simple
A friend told me that when storing my bayliner for the winter I should loosen the straps to reduce stress on the hull. Is he right?
WillyBWright
Re: transom tie down straps
Never heard that one before. Couldn't hurt. Just remember to snug them back up next season.
Mark42
I loosen the tie downs because they tend to make flat spots on the rub rails vinyl insert. During the summer, the flat spots pop back out in the sun, but I figgure that it just isn't good to have it compressed all winter. Plus, the boat isn't going anywhere....<br /><br />Mark
RedRangerVIP
Like Willy said, I never thought about it. It sure wouldn't be a pretty sight if you forgot to tighten them up next spring though.
garycinn
Originally posted by simple:<br /> A friend told me that when storing my bayliner for the winter I should loosen the straps to reduce stress on the hull. Is he right?
I have heard people say this, but I think it is an old wives tale. With a 3000 lb boat do you really think you are forcing the hull into the bunks more than the weight of the hull is? If so, loosen them up.
umblecumbuz
Better still - take them off and tie them to the trailer hitch. Then you'll have to move them before hitching up the boat next season, and - hopefully - you'll put them back in the right place!<br /><br />Ciao
f_inscreenname
I like to take them off for the winter. Mine will get wet if it rains and I don't want a wet strap pressed against the hull for months.
AMD Rules
I saw another post, which recommeded to loosen or remove the bow strap as well. That makes sense to me, as a tightly stretched wet strap would deteriorate over time. This is assuming the boat will not roll off the trailer without it secured. I woudl leave the back-up safety chain attached to the bow eye just in case.
jlinder
I suspect this could be a different story if you have rollers, but I have bunks and there is no way my boat is going anywhere with or without straps. Might as well take the strain off them.
NYMINUTE
I pull mine off, and loosen the bow strap, which will be covered. Its not going any where w/o tires on the trailer (I Hope)
Northern Eclipse
I loosen the straps when the boat is laid up, I'm not worried about stressing the hull, I you can stress or break the hull with straps, do you really want to hit a 3 foot wave in the thing, I loosen to take the stress of the straps.
