Re: Ski locker always wet?
Chris,<br /><br />Mine is all fiberglass, but added black vynel runner to help cushion. I just laid it into the locker. I had it slide down and cover the drain hole, and pool a small amount of water. Probably a couple dabs of adheasive will hold it, and still be able to remove it, if need be. If you are talking rubber bedliner, that will work. I use that on my floor in my 14' alum fishing boat. I wouldn't use any of spray on/paint on, too permenent.<br /><br />PS: I always take the ski locker cover off, and turn it 90 degrees, and set it over the hole, when boat is not being used. I also pull front bow cussions and leave the engine cover open a tad. Air circulation, is a good thing.
