ATTENTION JOE REEVES or any other Evinrude doctor
Motown
I have an old 1958 Evinrude big twin 35 horse that I just picked up that needs some doctoring up. First there was no ignition box (everything that plugs into the motor including the plug was gone) They were basically hot wiring it. So I (and I'm a Chevy guy so this hurts) got an old ford solenoid and an ignition switch and wired it all up. Then I had to buy the clamp that connects the linkage rods for the gears, It was all stripped out. I also noticed I have some kind of oil coming out of the water exhaust(or whatever it's supposed to be called) It's not gear lube. Are these motors lubricated internally at all? It seems to be black, and the thing smokes terribly. ANY help would be wonderful. THANK YOU (The thought was buy the motor cheap and fix it as I go along)
Joe Reeves
Re: ATTENTION JOE REEVES or any other Evinrude doctor
Motown.... Use Champion J6C s/plugs, gap set at .030. That "Black" substance is more than likely a heavy gas oil mixture draining down through the carbon/soot encrusted exhaust passagway (exhaust housing).<br /><br />Use "HiVis" (80/90w) lube in the lower unit, available at Wal*Mart, K-Mart, and of course your local marine dealership.<br /><br />Remove, clean, and rebuild the carburetor (trust me, it needs it). A carb kit should be available at NAPA or your dealership. Casrb adjustments are as follows.<br /><br />(Carburetor Adjustments - Two Adjustable N/Vs) <br /><br />Initial settings are: Bottom high speed = seat gently, then open 1 turn out. Top slow speed = seat gently, then open 1-1/2 turns. <br /><br />Setting the high and low needle valves properly: <br /><br />NOTE: For engines that DO NOT have a shift selection, obviously there is no NEUTRAL position. Simply lower the rpms to the lowest setting to obtain the low speed needle valve adjustment.<br /><br />(High Speed) Start engine (it will run pretty rough), shift into forward gear, take up to full throttle. In segments of 1/8 turn, waiting for the engine to respond between turns, start turning in the bottom high speed needle valve. You'll reach a point whereas the engine will either start to die out or spit back (sounds like a mild backfire). At that point, back out the needle valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest setting. <br /><br />(Low Speed) Slow the engine down to where it just stays running. Shift into neutral. Again in segments of 1/8 turns, start to turn the top needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running. Eventually you'll hit the point where the engine wants to die out or it will spit back. Again, at that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting. <br /><br />When you have finished the above adjustments, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
Motown
THANK YOU THANK YOU THANK YOU and THANK YOU AGAIN. THE one thing I forgot to mention (I THINK) was the carb adjustment (I had to tear it all apart it wasnt getting gas because it was full of dirt and didnt know how to set the carb again and you answered that too. Man I really appreciate this. Ron from Michigan
steelespike
No question Joe is the man.<br />Only thing I weould add is an automotive switch wont work on your motor.<br /> Outboard switch is on in the open position and off in the closed position, like a lawnmower.
Lark40
You also asked about internal lubrication. The engine internals are lubed by the two-stroke oil mixed into the gas tank. For 1958, the mix is 24:1, which is a quart of oil to six gallons of gas. Expect a lot of smoke. Some, but not most owners, suggest a slightly less mixture.
