Emergency bypass surgery
Molarman
Enjoy this forum very much. Have a 1987 28 hp Evinrude with electric start. Would like to know in an emergency can the ignition switch and kill switch be by-passed with a "hot wire" directly from the +pole on the battery to start the engine.<br />Where would the wire be connected and once started would removing this wire shut her down.<br />Thanks for a reply
Hooty
Re: Emergency bypass surgery
Molarman eh?<br /><br />Well I've got this tooth see...<br /><br />Welcome to iboats Molarman.<br />You can jump from the + side of the battery to the small + post on the starter solenoid and that will pull the solenoid in and should spin the starter or you can use a large wire (4-6awg) and go directly to the the big post on the starter. I'd use the small wire to the solenoid, myself.<br /><br />c/6<br /><br />Hooty
steelespike
If I understand you right you are talking about an on off switch.Motor runs on an open circuit like a lawnmower the switch closes to ground to stop the motor.Starting is as hooty describes.<br /> motor will run with harness unpluged and <br /> choking will work as a temporary way to stop.
alcan
Hi Molar<br />Why not just pull the rope?
