112 SPL Evinrude RPM's @ WOT
Chappie
I just bought a boat with a 112 SPL Evinrude which runs like a champ (after lower unit seal, water pump and thermostat change). I had it out today and was wondering what a good RPM reading would be at idle and WOT. Thanks.
D
DJ
Guest
Re: 112 SPL Evinrude RPM's @ WOT
Chapster,<br /><br />That engine is designed to run at WOT between 4500 and 5500.<br /><br />I would prop it so that it runs toward the top end of that range-with a light to moderate load in the boat.
Chappie
Thanks DJohns!!! I was getting WOT readings of 4800 today so i guess i am right in the middle of the curve. Thanks again
D
DJ
Guest
Chapster,<br /><br />If you buy a spare prop. Drop in pitch by 2".<br /><br />I would be willing to bet you're running a 13 1/4" X 19". A 13 1/4 X 17" would be better.
