throttle linkage 58 Johnson 35hp
hawker
throttle linkage 58 Johnson 35hp.The tall shaft that sits inside the horizontal worm gear on the engin throttle control has a key way that allows the tall upward shaft to turn.I need the key.They are made of plastic and mine broke.Hope someone can help.
Lark40
Re: throttle linkage 58 Johnson 35hp
Are you referring to where the steering handle connects to the lever which rises up the armature plate? Or, a smaller linkage that is connected to the carb?<br /><br />If you mean the item that turns the tall shaft from the handle, that is part # 304155 "Control lever to gear pin". <br /><br />Try your local Johnson/Evinrude dealer.
Paul Moir
One on my engine was broke. One on my parts engine was broke too. I made a new one out of a stainless bolt (non threaded part) instead of nylon, now I feel safer.
hawker
Thanks to Lark 40 and Paul Moir.It is great to have the help with these old motors.You guys really know your stuff.thanks again,hawker
