Re: 1999 ficht evinrude
I own a 1999 200 Ficht that I purchased new and had the power head replaced in 2000 and other upgrades in 2001 The power trim unit went in 2005 which cost $1600.00. The ECU (Electronic Control Unit) just went and it cost $2,000.00 to replace, and I'm still trying to get the engine to run right. It has not run the same since the new ECM was programed by the factory and installed on my motor.
If I had it to do over again, I wouldn't touch this motor with a 10' pole, let alone invest $15,000 in a new one. A used evinrude Ficht, or a new Evinrude E-Tec are the last two engines in the world I would consider buying.
The only way I would consider it would be with a 10 year minimum unlimited warranty and you know that isn't going to happen.
