JOHSON 140 POWER TRIM SWITCH
musky3
I HAVE ABOUT 15 HOURS ON MY JOHNSON 140 4 STROKE AND I AM ON MY THIRD POWER TRIM SWITCH (ON THE THROTTLE)THE SWITCH IS HARD WHEN TRIMMIMG THE MOTOR DOWN.AFTER A COUPLE HOURS MY THUMB IS SORE FROM PRESSING ON THE SWITCH.IS THERE A RECALL ON THIS PART? ANYBODY ELSE HAVE ANY PROBLEMS WITH THIS SWITCH?ARE THE CONTROLS MADE BY OMC OR SUZUKI?
mtemple
Re: JOHSON 140 POWER TRIM SWITCH
I have A new 115 Johnson four stroke (ala Suzuki) I noticed the same with the trim switch. I haven't broken it yet (thirty - forty hours) but I definately is not easy to engage.
aero320
Musky, I had the exact same problem on my new Johson (Suzuki) 140 four stroke. They have a relay kit that solves the problem. Evidently Suzuki uses higher voltage or current for their trim switches. There is a relay kit from Johnson that solves the problem. Will try to find the number. Was Supplied along with a new trim switch under warranty. I replaced it this weekend and it works great. The relay kit plug in between the switch and wiring harness.
aero320
Musky: Kit part # 0586806 Cable & Relay.<br /><br />Call your dealer and have him order it along with a new trim switch. Hope this helps.
musky3
HEY AERO320 THANKS FOR THE INFO I WILL CALL THE DEALER....THIS IS A GREAT SITE
