35 HP Evinrude, runs and starts sporatically
dsmith82
35 hp Evinrude Model E35ECIG Serial # E0002200First, I believe this is a 1981 engine, but please confirm.<br /><br />It seems like I have a mixture of several of the more common problems, so hopefully this will help others.<br /><br />It takes a long time to get started, and I use the "ear Muffs," prior to launching so as not to embrass myself at the launch. A :mad: fter about 5 minutes I get it running and it idles fine with a good amount of water coming out of the exhaust.<br /><br />Sure enough, I get to the launch and to everyone's amusement, it now takes 10 minutes to start, and afterwards I roar off into the river. Then, when I try to run at low speeds or idle, it shuts down. I try and start it again, and it takes about 20 minutes to get started (as if there was no spark). <br /><br />I am really landlocked due to the unreliability, and fact that I might not make it back to the launch..<br /><br />Signed, "He who gets back home via trolling motor..."
crazidan
Re: 35 HP Evinrude, runs and starts sporatically
check the sensor plate for binding or hard to move<br />if not its the carb
dsmith82
Ok...will do- where is the sensor plate? I don't see a diagram in the manual?? What am I looking for?<br /><br />Thanks
crazidan
the plate that under the flywheel that ajust the timming
Boatman
Dumb question.<br /><br />How old is your gas? Are you getting fuel to the carb? Do you have the correct plugs (I think they are QL77JC4 champions (someone correct me if I am wrong, I dont have my book in front of me) Also are the plugs in good shape? Is your fuel bulb on the line pumping up hard?<br /><br />Just a few things to look for
dsmith82
I think the problem was with the sensor plate sticking ( a little W-40 did the trick there), and the idle switch had come loose from losing the cotter pin- so I replaced that as well.<br /><br />The Plugs are brand new. The gas is about 3 weeks old, but it has been raining heavily here so possible water issue eventhough the boat is covered appropriately-I added a little Gas additive that supposedly helps any water "Pass" through the carburator.<br /><br />I have a 6 gallon tank, and I always wanted to know if the vent cap should be left wide open, shut, or simply unscrewed half-way. This probably effects the capability of the engine to draw fuel???
trumpetbucks
Well, it seems you've solved the hard to start problem.<br /><br />You are correct that this model number is for a 1981.<br /><br />I'm not sure about the vent question. You could also consider adding a fuel/water separator type filter between the tank and the motor to help prevent water problems in the future.
dsmith82
Thanks for the idea...a friend of mine said that the definition of a boat is:<br /><br />"a whole in the water that you throw money into!"<br /><br />Luckily all of my repairs have been quite inexpensive on this good ole' 35 HP reliable Evinrude.
