Getting air to the carbs, Johnson 120 hp???
anonym
Maybe this is a silly question. :confused: I have a 1992 120 hp Johnson. I wonder how the carbs get the air to mix with the fuel. On another of my Johnson engines, I see an air intake at the carbs, but the intake to the carbs of the 1992 Johnson has a plastic cover with no holes in it.<br /><br />Don't laugh too much after reading this posting, please! :D <br /><br />Cheers!
Bear
Re: Getting air to the carbs, Johnson 120 hp???
So you didn't get the hole kit? They comes in a plastic bag. You fit them like stickers where you like. (A joke. :D )<br />Check the picture.<br /> http://www.boaterssupply.com/images/fiche/big/4349961292.GIF <br /><br />Hej Göte!<br /><br />Köp en påse med hål och sätt dem på luftburken ;) På bilden ser du hur insugningsljuddämparen ser ut. Antar att du bara tittat från utsidan.<br /><br />Mvh<br />Björn
anonym
Ähum... Vilken av delarna (nummer på sprängskissen) är "insugningsljuddämparen"? :confused: <br /><br />(Jag är helt rudis ;) )
93bronco
Ensign
there are a row of holes on each side of the silencer <airbox>.
Bear
#53 bottom <br />#60 middle<br />#19 top<br /><br />The main parts of the silencer. :)
