Evinrude year no I dea
AFishin69
--- Still can't figure out my motor year, anyone know what year's they made starflites,when was 135 started that would help!
trumpetbucks
Re: Evinrude year no I dea
Do you have the model number from the top of the engine block? I have a '72 Starflite 100 and the only way I figured out the year was by looking up the model number from the engine block.
AFishin69
All I could find was#318147, does that help?
trumpetbucks
That number series doesn't come up to any model/year combination. The top of my engine block (on the starboard side) has two sets of numbers etched in it: the first set is 100293R which is the one I used to find out it was a 1972 100 HP Starflite. The second set on mine is similar to what you posted, and I'm guessing that's the serial number.<br /><br />No luck finding any other numbers?
Moving Target
Your Johnson/Evinrude dealer can get you the year and model number from the serial number.
trumpetbucks
Bailey:<br /><br />In looking at a spark plug catalog, 135s are listed from 73-84, so it could be any year between those, but I think Starflites stopped in 76 or 77. If you can't find another number (the model/year number) then I would go with Moving Target's suggestion and check with a dealer.
Bear
"when was 135 started"<br /><br />These are the 135 hp Evin model numbers:<br />135383 135 1973 <br />135443 135 1974 <br />135483 135 1974 <br />135489 135 1974 <br />135543 135 1975 <br />135583 135 1975 <br />135589 135 1975 <br />135643 135 1976 <br />135683 135 1976 <br /><br />Pictures: <br /><br />1973 135 hp <br /> 1974 135 hp <br /><br />I hope that helps
AFishin69
Bear..you got it its exactly it 1973 135 Evinrude!!! thanks now I know what I am working with! Was that a good motot anyone know..its history!
