over powered wooden boat
flote
hello, i have a 1956 18' "whirlwind", this boat is made of laminated and formed mahoghony,it weighs 220 lbs. it is powered by a 1965 johnson 75. the engine is greatb ut needless to say it's a bit much. please send any recommendations on a more suitable engine and any ideas appraising the '65 johnson. thank you for any help. <br />flote
TELMANMN
Re: over powered wooden boat
I would think the boat is worth more then the motor. Does it have a plate with max. hp.? If the motor is over that rating I personnaly would find a motor within those specs., the lighter the better. Wood boats are jewels. My opinion.
Solittle
If the engine is running great - keep it - just keep a light foot on the throttle.
OBJ
Hi flote....if you believe that there is a safety factor here, ie...to much motor, to little boat, by all means get a smaller more managable motor. Never put your safety at risk on the water. Perhaps a motor of 40hp would suffice....220lbs ain't a lot to push. Good Luck.
SeaMasterZ@aol.com
220 pounds and 18 feet long?<br /><br />WOOD???<br /><br />My Starcraft wieghs more than that, and its made of aluminum, I dunno, you SURE about that wieght?<br /><br />I could see if it was a little 12 footer or something<br /><br />does the engine run well, respond well? does the boat work well with the motor?<br /><br />if it aint broke, dont fix it!<br /><br />(I buy em busted, so its not a prob for me, lol)
Kenny Bush
Flote, no question about it....... 3.4l Merc 300 hp on a 30" bracket... Order the large bennet trim tabs with the Trimdicators. Of course you will have to upgrade the steering a little. :eek: :eek: ;)
cbrockett
flote the motors are selling on ebay anywhere form $100-$300 depending on the condition. 40hp is on ebay not and it is going for about $150, but a 60hp bad condition is $86 and a 75hp 1962 model sold for $260 yesterday in good condition. Hope this helps
Cut n' Jump
yeah but ebay prices are different from one you can hear run or drive around the lake with.
