jeremyeasen
Thread starter- Joined
- Jun 20, 2002
- 72
I have a 1990 Johnson 115 and it has a distinct hesitation when the key is turned. The battery is new and fully charged, i tested the starter off the motor with cables and its fine. I have checked every connection to and from the starter. I have correct voltage at the starter. Like i said all connections are brand new and the 20amp fuse is good. Is there an impedance test or something i can do to rule out the solenoid? That is the only thing i can deduct. The motor starts, but the starter engages, hesitates, and kicks back in at full capacity. thank you all.
