Tiller Handle Question
dcparizo
Someone selling 25hp Johnson Outboard Tiller Arm removed from a 1972 motor.<br /><br />The Tiller Arm should fit all Johnson & Evinrude 5.5hp up to 25hp (Except the 9.5hp) from the late 1950's up to the late 1970's with the rounded-ball type gear teeth.<br /><br />wondering if this arm will fit a 35 hp - '57 Johnson RDE-19?<br /><br />Thanks In advance
JB
Re: Tiller Handle Question
Howdy, CG.<br /><br />Moving this to Outboards.
wizeazz
You just used up your last chance, Wizeazz.<br /><br />Bye. :D <br /><br />JB
dcparizo
sry bout the wrong post. <br /><br />Please help a newbie out here. Reply says this<br />was moved to "outboards" ... I only see an "outboard motors" and an "outboard repairs"<br /><br />So where did this get moved to?<br />and Is it still under the same message.<br /><br />Sorry if this is not posted to the correct spot either .... As the name implies ... I need a computer to do just about anything.<br /><br />Thanks in advance
