89 Johnson 175HP Tachometer
Jkurtz29
Bought a new boat a few weeks ago with a 89 Johnson 175 HP on it. Runs like a champ. Love the thing. The other day the Tachometer just quit working while flying across the lake. Trying to figure out what went wrong. Fuse, wiring... ect. Called Johnson and they told me it needed a new rectifier regulator ($205). SOunds pretty easy to install. Before I shell out the bucks, I wanted to check and see with others whether or not there could be anything else I could check first? The grey wire? Fuses, Batteries?, wiring? Not sure where to start. Also, I can I run the boat until I get this fixed? I don't see the harm but I could be wrong. Thanks for the help.<br /><br />Jason
moderator1
Re: 89 Johnson 175HP Tachometer
jkurtz29,<br /><br />This is your fourth post asking exactly the same question. If you want to move the post up on the board just reply to yourself. Do not keep re-posting.
D
DJ
Guest
It could be your rectifier. Easy to check. If the rectifier is bad, your battery will not recharge.<br /><br />Is your volt meter reading greater than 12V with the engine running? If it is, your rectifier is OK.
Jkurtz29
Yes batteries recharge fine. Could it be because I did not charge them prior to going out last time? Can an engine run at a lower charge than the tachometer. The engine turns over very well and runs great. <br /><br />JK
D
DJ
Guest
Without voltmeter (in dash or hand held) verification, we're only guessing.
Jkurtz29
Good point. I'm going to run out and get a volt meter. Hopefully bring some clarity to the situation. Could this be a potiential issue the the altenator? <br /><br />Thanks for your help. I will keep you posted.<br /><br />Jason
D
DJ
Guest
Get one with an ohm feature too. It may come in handy, down the road.
moderator1
Please do not double post with the same question. Board space is at a premium.<br /><br />Plus, if you double post, nobody has any idea what you have already done. I have deleted your new post and added it to this string.
moderator1
Jkurtz29 <br />First Mate <br />Member # 28344 <br /><br /> posted July 17, 2003 04:03 PM <br />--------------------------------------------------------------------------------<br />Sucker went dead the other day. Outside the standard stuff like... grey wire this grey wire that, rectifier regulator.. is there anything else I can check? Low bateries, fuse... before I buy a 200 part and rip the engine apart? <br />--------------------------------------------------------------------------------<br />Posts: 12 | Registered: Jul 2003 | IP: Logged
Sal G
Engine should still run- just not charge. Would run off the battery until you deplete it/them. If your engine doesn't turn over- its probably your battery or a faulty connection to starter/ corroded or dirty cable connectors giving your not insufficient amps to crank engine. The tach thing is a correct indication of a faulty alt/rect but the usual symptom is INTERMITTANT tach reading -usually doesn't shut down all at once unless you blew it out completely by shorting out the system.<br />Single or dual battery system? Before you buy a<br />new part check out and clean your connections.<br />If your not getting a charge back to your battery once you get the engine goiug then I suspect a bad <br />alt/rec. A solar trickle charge battery charger<br />that works off your cig lighter is a good investment
