water pump
papasage
replaced the water pump on 1974 70 hp .no water out the upper exzoust holes till warmup leaver is over half way up .thin there is a goodstream. no water at idle. is this normal. papasage
OBJ
Re: water pump
Hi papasage....don't think you will see much coming from these ports until the T-stats open. What comes out then is usually a "spray" type of output as most of the water output is through the exhaust cavity and out the prop hub. If engine is runnig a good temp and a little is coming out, should be good to go.
papasage
Re: water pump
thanks jim . i let it run in a tank till the head got hot enough that i just could hold my finger on it till the count of 5 . the 5 was quick . seams like that was as hot as it got . bringing the rpms up would let water come out of the ports .thin it would cool down . at idle no sign of a spray . was wondering if i need to change the plate under the pump. papasage thanks
papasage
Re: water pump
took the 1974 70 hp. out yesterday it ran great . still gitting water in the foot . i had changedone coilrectofier waterpump and seals in the foot.i guess i goofed somewhere onthe foot.back to the foot . maby this time
OBJ
Re: water pump
Best way to find the leak is to drain out the lube and put a few pounds of air in the lower unit and put her in the tank. Leaks will show up right away. Knowing what seal is leaking makes it easier than guessing or replacing them all again.
papasage
Re: water pump
thanks obj . i think i herd of that on a back post . just have to rig something up . if my memory is right . 10 lb . of preasure is what the preasure is supose to be to check .papasage
wikelam
Re: water pump
great to see you got the 70hp going. Still working on the 50hp. fuel pump leaking. runs great though. do not want to run it too much with leaking fuel, that could be bad. fired up the 40hp. carb overflows. could be stuck from the ride to OK. by the way, THANKS for the forms you filled out and sent back. Wikelam from OK.
papasage
Re: water pump
wilkie the forty hasent ben run for awhile . just rebuilt the carb befor i took it off the boat but it has sat for a while . it has never failewd to crank . it just didnt have the charging systom .a good battery will last allday .
