1984 Johnson 90HP - Is this really an air leak?
kenpars
I just wanted to correct some mistakes in my earlier posting. This motor is actually a 1984. Sorry OB if your advice isn't valid for my motor. I did check the timing ring return spring - couldn't find the plastic post, but it does appear to be working properly. The timing ring can travel from stop to stop.<br /><br />----------------------------------------<br /><br />Hello everyone,<br /><br />I wrote in a few weeks ago regarding this boat. At the time I had a problem with low power. I think I solved that problem by making sure that all 4 coils were properly grounded to the block. Now the problem is that ever since then the engine has been idling very fast (3000+ rpm) when in the driveway with the earmuffs on. I have now taken the carbs off 3 times to inspect and I am sure that there are no carb-related air leaks. I have also cleaned all the jets on the carb. They are all original jets and have not been changed out since the boat was running properly.<br /><br />I have tried adjusting the idle speed stop on the throttle arm linkage, but this has no affect on the carb throttle plates since there is already a gap between the throttle cam and the carb roller. The carb throttle plates are definately closed and centered in the barrel. I guess my question is where do I check next? Will the RPMs go down when the boat is actually in the water and the exhaust has the extra backpressure?<br /><br />Any help is very much appreciated. My wife thinks this boat is a money pit and will never run right. <br />--------------------------------------------------------------------------------<br />Posts: 5 | From: Huntsville, Ontario | Registered: Jul 2003 | IP: Logged <br /> <br />ob <br />Admiral <br />Member # 15076 <br /><br /> posted July 22, 2003 03:28 PM <br />--------------------------------------------------------------------------------<br />Are the carb flaps indeed closed fully? If so your engine may have its timing advanced way off mark.Does the timer plate move freely from stop to stop when the throttle is operated?Insure that the timer plate return spring is secure on its plastic post. <br />--------------------------------------------------------------------------------<br />Posts: 2498 | From: corpus christi texas | Registered: Aug 2002 | IP: Logged <br /> <br />kenpars <br />First Mate <br />Member # 27683 <br /><br /> posted July 22, 2003 03:41 PM <br />--------------------------------------------------------------------------------<br />OB,<br /><br />Thanks for the reply.<br /><br />I have watched the timing ring rotate and it appears to be fine. I don't remember seeing the return spring plastic post, so I will look at that tonight. I have tried adjusting the throttle / timing arm stop screw to both extremes of its motion without any affect on the speed.<br /><br />One other observation is that the motor has become hard to start and actually tries to turn backwards sometimes when the starter is turning it. Ususally right before if finally starts and revs out of control. Maybe there is something to the timing being too advanced. <br />--------------------------------------------------------------------------------<br />Posts: 5 | From: Huntsville, Ontario | Registered: Jul 2003 | IP: Logged
Dhadley
Re: 1984 Johnson 90HP - Is this really an air leak?
When it starts is the flywheel rotating clockwise or counter clockwise?
kenpars
It is rotating clockwise
Dhadley
Good. Verify that the primary and secondary coil wires are correctly located and not crossed. If they are all in the right order remove the flywheel and verify that the key is not sheared.<br /><br />Let us know how you make out!
kenpars
That's it. I checked the flywheel and I didn't even have to remove the nut to check that the key was sheared - I could tell by putting cylinder #1 in approximately TDC that the flywheel was around 20-30 degrees advanced from where it should be. I imagine that this could explain all kinds of problems that I have been experiencing. It surprises me that the engine even ran at all.<br /><br />Thanks to Dhadley and J. Reeves who had also suggested this as a possible trouble shooting check in an earlier posting.<br /><br />I'll let everyone know once I change out the key and start it up.
