Tinkerer(ghost)
Thread starter- Joined
- Jul 10, 2003
- 9
Clymer refers to some tool for gripping the flywheel while trying to remove the flywheel nut, but I doubt I can locate one or justify the cost for one use even if I found it.<br /><br />Tried rope around around flywheel tied to lifiting ring and, after telling my kid I'd probably break it when I leant on spanner, I broke it.<br /><br />Solution. Remove two bolts from outer ring of flywheel and drill two holes through thick angle iron to fit bolts back through to holes. As I work single handed I used a short length and braced it against the starter pinion housing, but you could make it longer and have a mate hold the other end to avoid damaging anything. <br /><br />Strong tug on the nut and off she came.
