stainless prop slowing down the boat
minocqa
hi<br />i have a 1976 70hp johnson<br />i put on a new stainless steel prop on my boat and the darn thing goes slower than it did before :confused: <br />i put the aluminum back on and the speed returned <br />they are both the same pitch i want to say <br />13 1/4 x 17, but they was both the same size.<br />its got me confused<br />thanks<br />Don
Reel Appeal
Re: stainless prop slowing down the boat
One prop may be a "cupped" prop,the other may not.<br />Thickness of the blades can also affect speed/drag.The aluminum prop may have thinner blades.There are also design variations that can have negative(or positive) performance on your boat.
Bob in Calif.
What was the RPM reading using each prop, with the throttle wide open? ...Bob in Calif...
Cricket Too
Is the prop brand new or just new for you? If it is used check the hub.
minocqa
hi<br />the SS prop is brand new and it is a cupped prop.<br />the boat acted like it was draging a weight :confused: <br />Don
I can recognize a cupped prop pretty easy, but what does it do compared to a non cupped prop? <br /><br />Perhaps the prop wasn't suited to your boats performance abilities, but that doesn't make sense?<br /><br />Good luck, I thought a SS prop would reduce drag and be thinner than aluminium.
Bob in Calif.
As I recall, when you replace a non-cupped prop with a cupped prop, you should reduce the pitch by 2 inches. So your non-cupped prop of 13 1/4 X 17 should have been replaced by a 13 1/4 X 15 cupped prop. Does your engine have tilt and trim? If not, I believe the rule of a 2 inch drop would apply. ...Bob in Calif...
walleyehed
Bob in CA. has been doing his homework and is 100% correct- ya gotta drop 2" with a cupper. The best thing is, all flat, non-cupped props, have for the most part been discontinued.
wikelam
B in C, I am new to props. I have had boats and just put stock props on the motors. This info will help me in the future. thanx
