nitsuj
- Joined
- Jul 22, 2003
- 483
Hi all, this is my first post, I hope someone can help. I know this topic has been hit, but I haven't seen any one answer, and I have a twist I haven't seen mentioned yet. The motor is a 1971 115, hydro electric shift. When I first start it up, everything is fine. But after a few minutes, reverse won't work. I still have neutral, but pulling the lever back makes the boat go forward. If I pull the lever the whole way back, I go full speed ahead! It makes trailering interesting! I understand that it could be the solenoid, or the switch in the control housing. But why the first few minutes of normal operation? And how can I check it out of water? If it turns out to be the solenoid, how tough a job is it? I'm a motorcycle mechanic for a living with an extensive Snap-On collection, so I'm capable. Is the motor worth the trouble? Anyone ever converted one of these to non-electric shift? Should I just be looking for a newer boat? I admit, I'm somewhat attached to this one, but if it's just going to be junk, even when it is running, I'd just as soon chuck the whole thing. I should also remember that it's attached to a 1970 17 1/2 Glastron Semi V hull, and it will be used for weekend river running. Thanks for any words of advice.
