How Much is Too Much
mrcoop
95 Johnson 140....good compression on all 4 cyl, but.....<br />On the top of a piston head. How much pitting is too much pitting...to the point that the piston must be rebuilt or replaced?
JB
Re: How Much is Too Much
Examine the piston top. If there is too much pitting, replace it. If there is not too much, live with it.<br /><br />Now think about it. How would you answer the question??<br /><br />If compression is good (whatever the heck that is) don't worry about it.<br /><br />Good luck. :)
Dhadley
Ditto JB. <br /><br />Just be aware that the hardness of the piston is gone. The piston is now very weak compared to what its supposed to be. <br /><br />Find out why it did that in the first place. Now is the time to figure it out, not after you rebuild it.<br /><br />What spark plugs are you running?
mrcoop
thanks for the reply...compression is 120 on 3 of the 4 and 115 on the cyl that I can see a little pitting on the top of the piston head....Im running Champion Plugs spec gap for this engine. <br /><br />Possible Causes ruled out: plugged carbs, advanced timming, looking at the power pack (possibly a bad diode.)
