Need helper wrench, Daytona Beach FL
Tazman282
If there is anyone in this area that can help me work on my Engine please call 386-304-4354. I am willing to pay depending on the outcome. Please only serious people.
Tazman282
Re: Need helper wrench, Daytona Beach FL
by the way it is a 1984 140 Evinrude.
wayne h
what is the problem we might beable to help you here
Tazman282
Sorry I have been out of town so I have been unable to reply. I have tried everything that I know to do and have been on here many times trying to narrow it down. I can get it started eventually (usually) but then under power it just never gets into the higher RPM's. Then I had a problem with no power going to the ignition so rewired around it and got that going but not the right way. I have had problems with the Tilt and Trim. I drained refilled manually raised and lowered about 10 times let sit but it still will not work. The motor will run but it only moves like 1/4 inch. I think the engine just needs someone that knows something about it to take a look and work out the kinks. I know a little but not enough. I also am a little short on cash at the time. Which makes the 45 an hour kinda steep at most repair shops. Any ideas would be greatly appreciated. Thanks....
The Marine Doctor
We need to see some spec's...Compression...Spark...Carb's been done? ect.<br /><br />TMD
