Substitution of OMC products during water pump replacement
pbailey
Water pump kit calls for the use of:<br /><br />1. OMC Moly Lube<br />2. OMC Adhesive Sealant<br />3. OMC Triple-Guard Grease (is this white lithium gease?)<br />4. OMC Gasket Sealing Compound<br />5. OMC Outboard Lubricant (is this 2-stroke oil?)<br />6. OMC Needle Bearing Assembly Grease<br /><br />All of these products might not be readily available to me and possibly others.<br /><br />pbailey <br /><br />Are there substitutes that can be found at an auto parts store?
Solittle
Re: Substitution of OMC products during water pump replacement
What motor are you working on?<br /><br />Recently I put a OMC water pump kit in my 1987 V4. All I needed was a little bit of gasket sealer (Permatex in a metal can with a brush in the lid - auto parts store item or Sealer 1000) for the gasket and a bit of marine grease for the splines on the top of the driveshaft.<br /><br />An OMC shop manual helps but it ain't rocket science. The hardest part is reconnecting the shift rod which can require some fiddlin.
pbailey
It's a 1981 115 V4. I just picked up this motor and it runs well and the pump seems to be strong, but I don't know it's history. <br /><br />I'm having the same problem as an earlier post of last week where I'm getting water out of the top of the leg or shaft housing just under the lower cowling. Given this I don't think I can be trusting of putting it back together the way it come apart. Engine does not overheat. I can put my hand on the heads after warmup without discomfort.<br /><br />I have a Clymer manual and it's lacking in details, but an exploded and indexed view of the installation came with the kit. I'm pretty handy with my hands so I know I can do this. But the kit and the manual refers to the items listed in my original post.<br /><br />I want to do this right the first time so I want to use the products or it's equivalent as specified. The kit says to use item 4 above on the cup, but it dosen't say where to use it. Should it be put on the sides and bottom of the cup against the housing? <br /><br />Thanks for the help.<br /><br />pbailey
Joe Reeves
Baily.... Substitute as follows:<br /><br />1. OMC Moly Lube = Any anti corrosive lube/grease.<br /><br />2. OMC Adhesive Sealant = Marprox Sealer 1000, also available as Boat Armor Sealer 1000.<br /><br />3. OMC Triple-Guard Grease (is this white lithium gease?) = This is OMC's anti corrosive grease. Evinrude color is blue, Johnson is green. This is not the white lithium grease.<br /><br />4. OMC Gasket Sealing Compound = Regular gasket sealing compound. Comes in a can with a small brush in its screw off cap.<br /><br />5. OMC Outboard Lubricant (is this 2-stroke oil?) = I have no idea what they're referring to here, or for what purpose.<br /><br />6. OMC Needle Bearing Assembly Grease = Any anti corrosive grease.<br /><br />Bottom line = As follows:<br /><br />(Gasket Sealers - Available at any first rate automotive parts type store.)<br /><br />Do Not use any type of sealer on outboard carburetor or intake manifold gaskets as this would cause blockage of various fuel/air passageways. Also, there are new type gaskets which are used through out the engines that are coated with a substance that gives a shinny appearance to them. These gaskets are coated with a self sealer and are to be installed as is.... no sealers! Older style head and fuel related gaskets that are not coated with this substance are to be simply coated with oil.... nothing else.<br /> <br />All other gaskets (hopefully I've not overlooked anything above) should be coated with Gasket Sealer (the type that comes in a can that has a small brush in its screw off cap).<br /> <br />Sealer 1000 or OMC Adhesive (same substance) should be used on any metal to metal or metal to plastic surface (such as impeller hsg to plate) to eliminate air leaks. It should also be used on the Spaghetti tubing that is used on many powerhead crankcase halves, lower unit skegs, etc. I have found that this substance works quite well on various "O" Rings such as what are found on lower unit carrier and upper driveshaft bearing housings (Note that this substance is obviously not to be used on all "O" Rings).<br /> <br />DO NOT use any sealer on the large "O" Rings that are used on the upper and lower crankcase heads (The housing/heads that slide over the top and bottom of the crankshaft). On those "O" Rings, use only a coating of grease.<br /> <br />Sealer 1000 may also be found in other brand names such as "Boat Armor" but the name of Sealer 1000 will always be mentioned on the tube.<br /> <br />The exception of surface to surface contacts pertains to the later model matching crankcase (block) halves (which does not incorporate spaghetti tubing) which call for "Gel-Seal", or any other surface that calls for Gel-Seal. This substance seals in the absense of air, and if called for, must be used. One other form of Gel Seal that can be substituted is "Loctite #518". Nothing else that I know of will do!<br /><br />I advise against using silicone or permatex on a outboard engine. It simply will not function properly. The exception to this (as per OMC's recommendation), is to use the black Permatex (heavily) on the gasket 306242 which seperates the inner exhaust tube from the exhaust housing on the 1959 35hp and 1960 to 1970 40hp OMC outboards.
pbailey
Jim,<br /><br />Thanks for the info.<br /><br />pbailey
Joe Reeves
Jim???
pbailey
Sorry Joe,<br /><br />Thank you.<br /><br />pbailey
pbailey
Changed the water pump and found out why the water was coming out the top of the exhaust housing. <br /><br />The extension the connects the lower exhaust housing to the upper exhaust housing gaskets were distorted and not making a seal. Replaced and it took care of the problem. I would imagine that this is a common problem because it's a bear getting that all lined up when reinstalling and it's impossible to inspect after installation. :( <br /><br />I don't know how long this engine was run in this condition. Are there any known problems from extened running with this condition?<br /><br />Moved to the thermostats next and found that the the only thing left of them was the cone part facing the block. Everything else corroded away. I suspect that the pieces that left the t-stats might be hung up in the engine some where. :eek: <br /><br />Is there anything to do about that or should I just keep an eye on engine temps. <br /><br />pbailey
