blindwillsee
- Joined
- Jul 25, 2003
- 6
I have an older 35 HP Evinrude, I haven't checked the serial number for the exact year for sure but I think it is a 1980, at least that is what I was told from the previous owner. Anyway, the motor ran rough the first time out, I adjusted the idles speed tightened the plugs and also tightened the loose nuts on the carb. <br /><br />It then ran good at higher speeds, but would quit at idle. Adjusted idle speed and it worked good for one trip, the next trip the motor started to miss at higher speeds in about five second intervals. Looked things over checked the gaps on the plugs checked all bolts, nothing looked wrong. Gas is same that it ran good on so don't think that is it but will get different gas just in case. <br /><br />Now it misses really bad, getting into almost idle speed ranges. Plugs are fouling. Went and bought a small glass fuel filter, no change. Think it may be the timing since boat was ran with loose carb and loose plugs. Any help would be appreciated. <br /><br />blindwillsee
