Power pack problem?
egbaby
I'm new to this forum so please overlook any obvious mistakes.<br />My question is: I have a 1978 115 HP Johnson and<br />in the process of a shop orinated tune up. The carbs have been serviced with new kits, new feul<br />pump, new gas line from built-in gas tank, new spark plugs. The shop mechanic now tells me that the timing cannot be done acurately because one cylinder is not firing and that this is caused<br />from the powerpack on that side of the motor. He<br />says the coil for the nonfiring cylinder tests out<br />OK and that the powerpack is only functioning at <br />50%. I was under the impression that if a power pack went bad that it would not have any function at all.<br />I would like to see some comments on this subject.<br /><br />egbaby
angus63
Re: Power pack problem?
Did he swap powerpacks to confirm this?
Joe Reeves
EG..... Inside the powerpacks are electronic switches. It is possible to have one on those switches fail, affecting one cylinder only.<br /><br />You have two identical powerpacks, one on each bank. Switch the packs. If the problem follows the pack, the pack is faulty.
egbaby
THANKS TO ALL REPLYS.<br />TO JOE, I DON'T KNOW IF HE SWITCHED THE PACKS FOR THIS TEST. I'LL ASK HIM AT NEXT CONVENIENT TIME.<br />THANKS AGAIN.<br /><br />EG
