downjigger
Thread starter- Joined
- Mar 5, 2001
- 41
I removed the lower unit on my 72 Evinrude to check solenoid wires. I found a bare wire that apparently shorted things out. If I apply 12v power in the proper sequences will it shift while turning the the drive shaft by hand?<br /><br />Also, what should the ohmmeter be reading when I test these leads to ground. I'm getting a closed circuit both on green and blue. I also get a closed circuit when I test both leads together.<br /><br />Another interesting note: While researching availablity of shift selector( 275.00 at Stone's is too much!) I discovered that the pushbutton switch is made by GE and is shown on their website-its used as a switch for appliances. This explains why so many failures with these switches, they were not designed for this application and the blade and contact weaken causing all kinds of problems. I haven't been able to buy one yet but will let anyone interested know if I make out okay.<br /><br />And feedback is appreciated
