JOHNSON 70
jparker70
i changed the spark plugs and cleaned the carbs. <br />at the lake the motor cranked fine idles good, at about 1/2 throttle the motor starts skipping, missing. then let off idles fine still. cranked it again and did the same thing. now will not fire off. i did check the plugs on was a little black not all the way just on one side.<br /><br />the motor is a 1970 60 hp.<br /><br />thanks for any help.
boatin
Re: JOHNSON 70
Im not an expert, but it sounds to me {you said you cleaned the carbs} that you may want to look back over that.....or it could be as simple as having the wrong plugs hence the carbon on plug
boatin
Re: JOHNSON 70
My info goes back to 1973 ; sorry<br /> Anyone else know???
tad7777
Re: JOHNSON 70
i would check the compression first,,then if thats ok ,,it sounds like it is a carb adujustment,,tad
