How many volts should this motor be putting out? It reads 12.3 at idle as well as WOT? TIA
Q Quin Seaman Thread starter Joined Aug 6, 2001 Messages 51 Aug 12, 2003 #1 How many volts should this motor be putting out? It reads 12.3 at idle as well as WOT? TIA
S sparkroost Petty Officer 1st Class Joined Mar 23, 2003 Messages 312 Aug 12, 2003 #2 Re: 1995 70 hp Evinrude show 12.3 volts @ WOT Sounds like you have a bad rectifier/regulator, or broken/loose connection.
A airman Petty Officer 1st Class Joined Aug 9, 2003 Messages 332 Aug 12, 2003 #3 Re: 1995 70 hp Evinrude show 12.3 volts @ WOT A good battery reads 12.4 on its own. It doesn't sound to me like you're ever getting anything.
Boatist Rear Admiral Joined Apr 22, 2002 Messages 4,552 Aug 12, 2003 #4 Re: 1995 70 hp Evinrude show 12.3 volts @ WOT Quin<br />Static battery voltage is 12.6 Volts. For proper charging should be between 13.8 to 14.4 volts.
Q Quin Seaman Thread starter Joined Aug 6, 2001 Messages 51 Aug 13, 2003 #5 Re: 1995 70 hp Evinrude show 12.3 volts @ WOT Thanks for the replies,by the way, I did charge the battery and had used the boat 3 times so 12.3 is probably right if it wasn't charging.
