3 Questions on 1970 85hp Johnson
mrc
1) Excessive play in throttle cable, Is ths fixable?<br /> Accellerate to any given RPM and need to back <br /> the throttle off almost an inch of travel before<br /> any effect. Then need to throttle up almost an<br /> inch before the RPM's pick up. This is from the <br /> remote control throttle, not at the engine. Ive <br /> had the remote apart, but nothing obvious on how<br /> to remove this play. The remote is Single lever<br /> with external key switch and no push buttons.<br /><br />2) Hard time getting into reverse. Electric shift.<br /> Will only pop into reverse at very low RPM's or<br /> if I start it in gear in reverse. Proper type C<br /> lubricant is installed. Neutral is fine as is<br /> forward.<br /><br />3) Electric Tilt... This is an electric tilt from a<br /> 1972 125. It will not stay tilted up. I have<br /> tried to remove the bypass valve screw after <br /> removing the snap ring, but stopped when I could<br /> not find what was preventing if from pulling out.<br /> Any suggestions? and am I on the right track as<br /> far as what is allowing the engine to tilt back<br /> down? (This is only a Tilt, not trim. It is<br /> supposed to support the motor in the up position<br /> the tilt cylinder replaces one of the tilt <br /> assist pistons and the pump is on the outside<br /> of the transom bracket, also has a seperate mini<br /> cylinder for operating the reverse lock)<br /><br />Thanks in advance,<br />Mike
mrc
Re: 3 Questions on 1970 85hp Johnson
^ anybody? <br /><br />Thanks in advance,<br />Mike
tad7777
check the throttle , by manualy moving it on the motor itself,to see if the rpm's changed..,sounds like alot of play in the cable or at one end or the other of connection,, the movement should be touchy,as far as throttling up or down,if you can visually see if the throttle is moving at the linkage connection,then check for any slop in the movment,,it is difficult to answer this question,without being able to look at the cable & linkage connections.
tad7777
on my evinrude,i can only changed gears foward or reverse at low rpm's this may be in the design,not a problem tad
mrc
Thanks for the response.<br /><br />It doesn't seem to be play in the cable as much<br />as play in the throttle lever to cable linkage.<br /><br />Regarding shifting, when I say low RPM I mean almost<br />stalled. ie, it will not shift into reverse at<br />800rpm (and I can hear gear scraping) but at <br />600rpm it might. My guess is something along the<br />weak solinoid, or oil pump. Anyway I'll probably<br />wait until fall when I pull the boat out and<br />to try and track this one down.<br /><br />Thanks again,<br />Mike
