I have a 92 Johnson 175 Silver Star mod# VJ175EXENC. I have had this motor for a little over three years. Recently I had it out and had been running it for about six hours( 3500 rpm for about an hour then trolling) when I decided to head back in. Got the boat on plane for about 10-15 min. and the motor just died, like I turned the switch off or pulled the kill switch. After several attmpts to start the motor it finally started, tried to get it up on plane and the same thing happened. Got it started again and pushed it up to 1800 rpm and it ran for about 2 hours that way on the way in. Then, it started happenng again and did it five or six more times on the way in. Spoke with a friend who had had a similar experience and he said it was water in the fuel. Drain the bowls on the carbs and drained the tank and installed a new separator filter but found no water. Spoke with a local o/b mech and he said that it sounded electrical and that it was probably in the key/kill switch or the elec. harness. Check the switches and harness as per my Clymer manual. On the key switch test i was moving some wires and the meter dipped. pulled the switch and fou that pushing on the rubber boot covering the M terminal the meter dipped. Pulled the bott back and found the wire was corroded. Stripped back the wire to clean wire(1/8 inch) and crimped on a new end. Thought that was it. Put the boat in the water and it ran, smoked a bit, but once up on plane it ran fine. ran it out to the old fishin' hole (about 30min.slowing down to idle,twice,to chase bait)and it never missed a lick. Sat there about an hour and decided to move. The motor would not start. pulled a plug to check for fire-none. put the plug back in and tried to start it. Fired right up. idled over to another spot(about 5min.) and sat there about 2 hrs. Went to leave, boat fired right up, idled into the channel, got up on plane at 4000rpm for about five min. then it just died again. Checked the fuel filter at the motor-clear.After several attempts got it to start but it was surging and then i got a warning horn. It would beep once every 5-6 seconds(not covered in the manual). Turnit off, started, put it in gear and ran at idle for about 20 min, then it died again. started it again, then every time I put it in gear it would die. had to get towed in. Got it half way back, tried to start it and it fired right up. got it back to the dock and tried to start it-no go.<br />Needless, I started my troubleshooting all over. Istarted with the key switch and it checked out okay. Then I read in a post that with plug at the power pack disconnected and the key sw. turn on there should be no voltage on the black/yellow wire. I checked mine, .018 volts DC. Switch off 0 volts. Could this be a problem? I have also conducted the power and charge coil resistance checks-both good. The coil output voltage tests are low. 39 volts AC and 106 volts AC. Readings were taken with a digital voltmeter and multplied by 1.414. Is a peak reading meter necessary or is my methodology correct? Several of the tests call for one.<br />I have spent the last four days going through the posts to find a similar problem with no luck but I am leaning towards the stator being the problem. Any suggestions would be greatly appreciated
