ignition trouble 1981 V4 rude 140
Big Tort
I lost spark to all four coils. I found a wire under the flywheel chaffed and shorted out against the under side of the flywheel. There is 12vdc on this wire.. Not sure what to check, maybe a fuse??, rectifier, stator.... Any suggestion out there??? Prior to this electrical short,the motor was running, but very rough.. Now I know why... <br /><br />Thanks.. This is a great web site...
Hooty
Re: ignition trouble 1981 V4 rude 140
What color wire?<br /><br />c/6<br /><br />Hooty
Big Tort
The wire is red and it is routed under the flywheel on the back side or prop side..
Big Tort
Does anyone out there have an idea or a lead as to what could cause this ignition system to quit. Looks like it might be the stator.???
moderator1
Moving to Johnson/Evinrude questions.
